  • 307 Vote(s) - 2.73 Average
Nice MC424 control box interface to intercom access
Hi All,
This is my first post so please go easy!
I need some help trying to connect intercom access to Nice MC424 control box: I see there is an AUX connection but no START or OPEN so I'm a little confused...Sad see attachment, if it worked, I read in the manual you can program the AUX to carry out various different modes, however still unsure.
I don't know which intercom would be best probably Videx 4000 Series audio kit?
Thanks in advance.
Nash
(04-11-2012, 11:22 PM)polomint Wrote: Hi All,
Thanks in advance.
Nash
You could wire the output of the Itercom into pins 11 (common) and Pin 15(step by step) this will trigger the gate to open. However make sure the output from the Videx Intercom is voltage free or it will cause damage to the Nice MC424 .
Thanks in advance.
Nash
Thank you Mark for your prompt reply, I didn't realise the STEP BY STEP was for this...I thought it would only move the gates in stages. I would have expected OPEN or something but the MC424 doesn't have this. I bear the voltage free in mind when hooking up the intercom!
  Nice Robus closing after photo Nexur 1 354 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 1,886 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 1,417 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 1,547 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 2,019 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 2,236 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 2,880 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 2,188 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 7,012 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 5,303 10-12-2024, 10:31 AM
Last Post: dmrgate
