  • 13 Vote(s) - 2.92 Average
Nice A400 automatic search
Hey everyone,
After days of avid searching the Internet for my problem, I stumbled upon this excellent forum.
I'm hoping I can get some help with my issue, or at least get some pointers from the more experienced users.
I have a Nice Wingokit WG400 with a Nice A400 control unit. I recently replaced the control unit with one of the same model and when setting it up, I run into a frustrating problem.
Gate set up:
  - 2 WG4000 motors for 2 gates
  - no connections for Photocells at all. The only things connected to the motherboard are the motors and all NC inputs are shorted to Common. No other accessories.
When doing the automatic search, a sequence begins, but it stops midway as described below:
– Motors open briefly, first M2 and then M1    - > runs OK
– Motor M1 closes until the closing mechanical stop is reached.   - > runs OK
– Motor M2 closes until the closing mechanical stop is reached    - > runs OK
– Motor M2 begins opening.  - > NOT OPENING
– After the programmed delay, motor M1 begins opening.   -> NOT OPENING
So the gates remain closed and never open to complete the sequence. A clicking sound from the control pannel is heard, like a switch trying to open/close, but the gates never open.
Any thoughts on what I should be checking ?
Thank you !
Found the bug! I had to connect the photocells for the automatic search to perform correctly. Testing with all NC inputs shorted to Common, did not cut it.
All is working fine now. The learning procedure completed successfully.
  Nice Robus closing after photo Nexur 1 352 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 1,883 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 1,417 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 1,546 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 2,019 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 2,236 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 2,880 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 2,187 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 7,012 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 5,303 10-12-2024, 10:31 AM
Last Post: dmrgate
