  • 23 Vote(s) - 3.13 Average
Nice MC824H Set Up issue
I wonder if someone can help. My gate had an issue and the power was cut, turned out to be a slug in the mains switch spur. Everything now powers up and it looks like it's reset. If i go through the setup procedure, i get to the part when you need to set up the movement/limits , i  then press stop and close for a few seconds, so l3&l4 should start flashing, but they never do. The Led's go to L3 & L4 for a brief seconds then just go back to L1. Any Idea what could cause that ?
Does your board contain dip switches for motor selection? if not, you have the older model. Follow the below.
1. Press and hold down the stop (set) and the close button, until L1 starts to flash faster, then
release. Now you need to press the open or close button to move the LED to the required
LED position to select the motor type.
L1 is for motor types MB4024, MB5024 and HY7024
L2 is for the ME3024
L3 is for the TO4024
L4 is for the TO5024
L5 is for the TO7024
2. Once on the correct LED for the motor, press and hold the stop button to memorise the
motor type, then L1 should be flashing again.
3. Now complete the search for the limits. Press and hold stop and close buttons until L3 and
L4 start to flash and you should hear the panel click, then release both buttons.
4. Motor 1 should start to close and finish in the fully closed position, then motor 2 should
follow and go to the fully closed position.
5. Motor 2 should then start to open and a few seconds later motor 1 should start to open.
Both opening to the fully open position.
6. They should then both come to the fully closed position. L3 and L4 should stop flashing, L1
and L2 should flash for a few seconds and go off.
7. There should be no LEDS on at all from L1 to L8. The Bluebus light should be flashing once
per second and the ‘STOP’ Led should be on at all time
Easygates
thanks, it is the older board, i did follow that and you never hear the click. I did set the motor to 4 (TO5024) , then when i press stop and close , for a few seconds the LED 3&4 flash then jump back to LED1.
  Nice Robus closing after photo Nexur 1 7,207 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 9,523 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 7,873 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 3,562 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,181 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,318 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 4,902 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 3,075 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,347 10-12-2024, 11:29 AM
  Potential Encoder Issue Ben_wing 1 3,667 09-12-2024, 12:57 PM
