  • 212 Vote(s) - 2.97 Average
BFT Gate Below Ground Hydraulic swing gates no pressure in one
I am in NZ and finding it difficult to get someone to service my gates.
I have very heavy wooden and metal gates with 2007 Installed hydraulic motors in the ground. One of the gates no longer has any tension in it, it swings quite freely in the wind. On opening and closing it doesn't quite make it to the stop position, maybe because it runs out of time as it is going slowly. Can anyone give me any guidance as to troubleshooting, what may be the problem/solution?
To access the motors the gates would need to be taken off, which would be quite a mission based on their weight.
I have tried the winding key supplied, turned the little 3 sided screw completely to the left and the right, it made no difference to the tension in the gate. I am not 100% sure what that key is for so at any rate!
I tried the company website, but couldn't find any trouble shooting manuals and their education area was blank.
Thank you.
From the information provided it sounds to me as if it could be lack of oil in the motors. If there's no pressure, then this may be the main cause.
  BFT Gate Motor - Not working elyoussef.ali 0 171 Yesterday, 07:19 AM
Last Post: elyoussef.ali
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 472 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 99,289 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 2,245 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 1,833 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 1,333 04-11-2024, 05:59 PM
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 3,129 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 2,971 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 8,601 14-06-2024, 12:12 PM
  Two BFT pairs of electric gates (one remote) Harry44 1 2,784 04-06-2024, 01:30 PM
