01-08-2018, 07:41 PM
Hi. New here. I have just installed my new gates The program is flashing on pcb board I have fitted radio frequency board but I don’t have any photo cells how do I short out them ? Thanks in advance
Came gates za3p
03-08-2018, 08:42 PM
2-1 / 2-c1/ 2-cx / there are three NC contact bridge them up Best Regards
03-01-2024, 12:39 PM
ZA3P Blew with a slug dancing across the board. Replaced with a brand new one and worked for 2 days then was tripping RCD in house. Removed board, no slug / insect, checked all wiring but keeps tripping RCD. Board has a Remootio 3 attached for wifi gate opening and lights that come on for 10 mins after gate activation. 2 arm gates ATS30 - any ideas?
Tested capacitors in arms, only thing I can think of is limit switch in arms was knackered by gate installer ~ 1 year ago - could the fault be with the arm?
04-01-2024, 10:12 AM
Hi Simon
I would suggest disconnecting all accessories from the board and run 1 motor at a time. This would determine whether it is a motor issue or a control board issue as i doubt both motors would cause the RCD to trip. Regards Easygates 1
EasyGates.co.uk - EasyGates Ltd
EasyGates Direct - Trade only accounts. Smart and Secure Center - Smart Home Products
07-01-2024, 07:11 PM
(04-01-2024, 10:12 AM)Michael Wrote: Hi Simon It was the courtesy light(s) - new bulbs purchased, reconnected, blew again so no lights. Different issue - limit switches are off on the board, but now left hand gate will open, but not close. I am guessing the Limit switch in the ATS30 is knackered (like the right hand gate is)? |
« Next Oldest | Next Newest »
| Gates not staying open | JimM169 | 1 | 2,592 |
21-05-2025, 02:55 PM Last Post: Jakedugmore |
| FAAC gates out of sync | TheDock | 1 | 3,280 |
21-08-2024, 12:21 PM Last Post: TheDock |
| Rigel 5 , gates won't open | Nameloc | 4 | 9,870 |
04-05-2024, 12:41 PM Last Post: Alee |
| Gates tripped | Phil.c | 3 | 5,840 |
01-05-2024, 09:34 AM Last Post: Phil.c |
| Came ZA3 gates stuck open | Ivorwindybottom | 0 | 2,895 |
18-02-2024, 06:29 PM Last Post: Ivorwindybottom |
| Electric Gates with AllMatic BIOS2 Unit | antsnaith | 3 | 7,766 |
31-01-2024, 08:22 AM Last Post: patronsecurity |
| Nice Gates not closing | StuL | 1 | 7,856 |
24-08-2023, 01:34 PM Last Post: JoeF |
| Gates Opening After Closing | tht7 | 2 | 15,334 |
30-07-2023, 12:30 PM Last Post: lcpbarbosa |
| Came gates stuck open. | Ring8180 | 7 | 29,794 |
23-02-2023, 01:08 PM Last Post: SamA |
| Aria 400 - gates keep opening and closing | objohnuk | 1 | 7,933 |
13-04-2022, 11:32 AM Last Post: JoeF |
