  • 31 Vote(s) - 2.9 Average
FAAC S450H Oil Leaks & Filling
Hi everyone,
I am new to this forum and seeking help regarding a pair of the above rams purchased new by me about 18 months ago. From day 1 they have leaked oil and whilst they are still working fine I believe that due to the loss of oil the rams should be topped up. I don't believe the leakage warrants having them repaired just at the moment. My question is how do I top up the oil. I already have the oil recommended by FAAC and I am familiar with the bleed screw half way along the rams where the long rods fasten the aluminium outer cover over the piston. Is this where they are filled and if so by how much oil?
Any advice would be greatly appreciated.
(27-03-2020, 08:42 PM)nalayensid Wrote: Hi everyone,
HI,
Hope you are well,
could you please provide the model number of your rams this should be on the base of the ram if you can do this we can advise on how this is completed
Hi and thanks for your reply. The type are S450H E124 CBAC. Many Thanks Alan
(03-04-2020, 04:56 PM)nalayensid Wrote: Hi and thanks for your reply. The type are S450H E124 CBAC. Many Thanks Alan
Good morning. Any info on this yet? I also have the S450, one of them also leaks sometimes but now I have the problem that the right wing  does not close with the force it had before, maybe because of a lack of oil?
greetings
  Faac 740D, Open further then limit, not closing emiel 1 185 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 2,759 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 2,574 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 2,736 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 1 2,660 12-08-2024, 03:52 PM
  FAAC problem dennisoates 0 2,189 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 7,120 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 5,577 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 6,564 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 5,400 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
