  • 281 Vote(s) - 2.8 Average
Robo RO1000 Control Board Problem
I have a Nice Robo RO1000 gate motor which has stopped working. I have tried power cycling the unit several times. There is power on the 24Vac terminals that supply the photocells etc. The LEDs indicating the input conditions are all correct, ie the NC are on and the NO are off. The limit switch turns off one or other LED as it should. I've tried connecting the common terminal to each of the open close and step by step terminals. The LED lights but nothing else happens. However, the OK LED is not lit at all. Even right after turning the power on it does't light or flash at all. Also the LED does not light on the radio board if I hold down the programming button. Is there a separate fuse supplying the microprocessor that would not also stop the input status LEDs from working? If there anything I can do or is the control board going to have to be replaced?
It turned out the main fuse was blown. Somehow enough current to light the LEDs was getting through, but not enough to run the microprocessor.
  Nice Control unit passcode removal Andruelectricgates 1 3,595 17-06-2025, 11:25 AM
Last Post: HarrisonN
  Nice Robus 250 HS Fuse Problem GLM 1 4,357 09-05-2025, 01:07 PM
  Nice Era EPMB 3 flashes not recognised by control unit budda 2 6,250 16-07-2024, 08:47 AM
  nice robus D400 smartphone control YOSH 1 5,333 05-03-2024, 04:45 PM
  nice mca424 board or motor fault xjust 0 7,246 13-02-2021, 10:37 PM
Last Post: xjust
  Nice TOO7500/ Mindy A60 Installation Problem Woody 1 9,738 22-08-2020, 02:31 PM
Last Post: Woody
  WiFi module for A60/A board Sakhtar 1 8,234 23-12-2019, 04:30 PM
  nice flo4r-s remote control question tibibond 2 19,532 04-03-2013, 10:06 PM
Last Post: tibibond
  Nice MC424 control box interface to intercom access polomint 2 20,465 05-11-2012, 05:36 PM
Last Post: polomint
