  • 13 Vote(s) - 2.92 Average
Adding Extra Photocells To CB22
Hello there!
First post so please treat me gently! I'm fitting a sliding gate with a CB22 controller.
I'd like to add a second pair of 771e photocells just higher up as the text suggests you should. Currently the only wiring diagram I have is in the manual as shown below:
Testing with a meter and the two CLOSE terminals don't have continuity?
I can't figure what the dotted line to 16 and other to 17 are supposed to signify.
I assume all the negatives common up but where do I connect the + of the new pair.
These will be one side of the gate. If I'd then like to add two pairs the other side of the gate. Are there any wiring diagrams to do this?
Hoping that all makes sense!
  chamberlain photocells wlehane 3 33,043 02-09-2019, 10:00 AM
Exclamation lift master SCS300 - photocells Willow 1 13,068 14-07-2016, 09:16 PM
Last Post: Willow
Exclamation lift master SCS300 - photocells Willow 0 9,691 13-07-2016, 11:19 AM
Last Post: Willow
  CB22 dead ... Pls help !!! joe_tim13 0 8,078 10-09-2015, 09:05 AM
Last Post: joe_tim13
  CB22 problem??? Bakota 0 10,801 16-11-2014, 02:25 PM
Last Post: Bakota
  cb24 photocells devonaloan 1 13,420 28-11-2011, 05:57 PM
  CB24 Kit with a single set of photocells JD1765 1 22,673 07-06-2010, 10:04 AM
  Photocells crafty 1 15,356 12-01-2010, 03:29 PM
  Wiring Photocells on the CB11 control board Sparky 2 25,437 28-06-2009, 10:19 PM
Last Post: Sparky
  LiftMaster CB11 Board Photocells inder 1 15,349 17-03-2009, 03:38 PM
