  • 15 Vote(s) - 2.4 Average
FAAC Eq45s , only Leaf A closing with remote
Folks , I have a FAAC E145s driving my 2 leaf gate system ,
I replaced the board after power issue , programmed the remotes ,
Both leafs open if I use the key pad , and only leaf A with the remote ,
Have cleared the master and re done , still no luck,
Any help appreciated
(01-03-2025, 05:09 PM)Cummil2 Wrote: Folks , I have a FAAC E145s driving my 2 leaf gate system ,
Thank you for your message.
Could you please advise me on what remotes that you have as there are three different types with different programming methods. You have the LC/RC, SLH/SLH LR and the DS versions, I do not think this will fix the issue but may be worth a try in case the panel is getting its wires crossed when carrying out the programming method; you could try a fresh battery too.
It sounds like you are programming the remotes in a pedestrian mode which is why the remotes only open one leaf.
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 5,651 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,323 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,052 13-03-2025, 10:06 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,766 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,388 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,377 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,117 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,768 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,526 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
  FAAC 400 cbac LN 104202 obey gates 1 12,073 21-11-2022, 09:54 AM
