  • 446 Vote(s) - 2.9 Average
chamberlain photocells
Hi - i have the cb11 a while but I'm now putting int he photocells, I have 1 set and when i connect the three leds on the board are flashing, do i need to connect a second set
You don't have to connect a second set, i always connect my one pair of photocells to open/close 23+ and common 24 - on the CB11 control panel.
But the more photocells you use on your installation the safer it it is!
if all three leds are still flashing red you probably haven't done this procedure correctly
Programming of failsafe photocells model 771E/770E
1.Before the Initial Setup
2.When connecting or removing photocell(s)
- Switch off control board ( disconnect from current)
- Slip jumper on designated pins
- Dipswitch 5 to “ON”
- Connect photocell(s) according illustration
- Reconnect control board, wait short-time
- Pull jumper, wait short-time
Done! (The number of photocells connected are stored)
hope that helps.
Hi is there an alternative photocell that is more robust than the 771E
(28-08-2019, 08:34 PM)Zammo_1 Wrote: Hi is there an alternative photocell that is more robust than the 771E
The CB11 only allows use of data photocells. I find the 772E photocells much better than the old 771E and they are fully compatible.
  Adding Extra Photocells To CB22 Onoff 0 7,459 06-08-2020, 01:01 AM
Last Post: Onoff
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 35,828 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
Exclamation lift master SCS300 - photocells Willow 1 13,065 14-07-2016, 09:16 PM
Last Post: Willow
Exclamation lift master SCS300 - photocells Willow 0 9,689 13-07-2016, 11:19 AM
Last Post: Willow
  Chamberlain Liftmaster gate problem CB1 tentotwo 1 15,562 28-03-2012, 12:55 PM
Last Post: Mark
  cb24 photocells devonaloan 1 13,417 28-11-2011, 05:57 PM
Last Post: Mark
  CB24 Kit with a single set of photocells JD1765 1 22,668 07-06-2010, 10:04 AM
  Photocells crafty 1 15,355 12-01-2010, 03:29 PM
  Wiring Photocells on the CB11 control board Sparky 2 25,436 28-06-2009, 10:19 PM
Last Post: Sparky
  LiftMaster CB11 Board Photocells inder 1 15,348 17-03-2009, 03:38 PM
Last Post: Mark
