  • 31 Vote(s) - 2.84 Average
Faac s800h
Hello I have a Faac double s800h swing gate . I’ve done the encoder update and installed a new control board plus faac photocells. I’ve opened the gates half way and placed system into its manually learning mode. Gate runs through the motions, once learning has completed it clicks out of the set up mode and the gate waits out the pause time and shuts. Now when I’m attempting to use the remote to open the gate, it clicks on the receiver and the control board open led lights up but gate does not open or even move at all. I’m not sure if I’m missing something or some  how my wiring isn’t correct. But Board doesn’t throw any errors and led system lights all show it’s good. I’m lost at this point and any help would be greatly appreciated.
Are you using 24 volt system or 240
What panel face e145 or e124
If it’s the latest version then you don’t do a set up from halfway
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 5,695 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,333 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,066 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,005 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,774 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,398 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,409 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,132 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,780 13-11-2023, 11:58 AM
Last Post: LoneStarCycler
