  • 22 Vote(s) - 3 Average
Wiring photocell to MC824H
I am replacing an old Nice A824 with a new MC824H and had hoped to simply follow the same wiring as in the old unit but obviously things have moved on.
I am using Came Doc-E (which I have no instructions for) photocells.
What I believe is the TX has two connections 24v + & - (so presumably they just need a 24v feed)
The RX has four connections the same 24v +&- (so presumably they just need a 24v feed). Then the two remaining wires from the RX are marked NC & Com.
My question is where do I put all these wires on the MC824H.
Any help really appreciated...
Unfortunately you are unable to wire relay photocells like the ones you have into an MC824H panel without having the OVIEW installer programming tool. This will allow you to change one of the inputs such as the open, close or SBS to a Foto input. As this tool can be expensive for one off use. You would need to purchase the NICE EPMB bluebus technology 2 wire photocells. These wire into the BUS terminal.
Not what I wanted to hear but appreciate the rsponse.
  Nice MC824H Set Up issue dmrgate 2 7,829 10-12-2024, 10:31 AM
Last Post: dmrgate
  MC424 PhotoCell Bypass for Constant Power AdamG 0 2,490 29-06-2024, 02:45 PM
Last Post: AdamG
  Nice MC800 Wiring issue Adamzsite 2 6,079 05-03-2024, 04:37 PM
  Nice photo sensor issue F210 and MC824H gates won’t operate Tantrum 1 10,900 04-01-2024, 10:06 AM
  Nice Robus RBA3c Wifi Relay Switch Wiring denis 1 7,669 01-11-2023, 09:45 AM
  Mc824h hold open Simonizzy 2 25,181 20-07-2020, 10:00 AM
  MC824H with Toons - learning process davidja 2 22,977 28-04-2020, 08:13 AM
Last Post: davidja
  How to connect two sets of photocell to wingo 5 swing motor Riyki 1 16,003 05-06-2018, 07:37 AM
  Blubus wiring coops 1 11,768 22-03-2017, 09:34 AM
  MC824H Simple Programming Guide easygates 2 27,865 25-03-2016, 09:43 PM
Last Post: Henwood_1988
