  • 28 Vote(s) - 2.89 Average
Nice remote fob
Can you reprogram a nice remote fob that has been used on a different gate? Tried pairing and doesn’t work! Think it needs wiping. Any ideas?
I have a nice robus 600 and couldn't find my remotes. Is it possible to buy new remotes online and program them without using the old ones.
Pls help
Quote:Hi
Can you reprogram a nice remote fob that has been used on a different gate? Tried pairing and doesn’t work! Think it needs new updates on this post regarding phenq wiping. Any ideas?
SAME QUESTION Sad
(24-08-2020, 08:28 AM)Deb Wrote: Hi
Hi Deb,
You are able to program other NICE remotes which have been programmed to another gate. This being said it must match the type of remote you already have. NICE manufacture multiple remotes and all of them may not be compatible with your system, or cannot be programmed at the same time as other types of remotes.
Do you have any information on the existing remotes or remote you are trying to program?
(12-09-2020, 07:27 PM)Farid Wrote: I have a nice robus 600 and couldn't find my remotes. Is it possible to buy new remotes online and program them without using the old ones.
Pls help
Hi Farid,
You can purchase new remotes from EasyGates Ltd. To program the remotes you would need to access the receiver inside the motor housing and follow the programming procedure for your receiver. The ROBUS will usually have the NICE OXI receiver inside. You can find the programming information on manuals.easygates.co.uk by searching robus 600
  Nice Robus closing after photo Nexur 1 7,250 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 9,586 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 7,921 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 3,602 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,238 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,366 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 4,943 16-02-2025, 05:16 PM
Last Post: gatekeeper
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 3,095 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,413 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 7,821 10-12-2024, 10:31 AM
Last Post: dmrgate
