  • 12 Vote(s) - 2.67 Average
Daitem intercom not working
I have a Diatem intercom keypad with single call button, coupled to a NICE gate opener, the keypad starting flashing repeatedly and then stopped working.
the internal intercom will open the gates, and the nice fobs will also open the gates, but the key pad didnt do anything at all.
I changed the battery in the external controller and this allows the keypad to open the gate and call the internal handset - but it wont beep or light up?
any ideas.... ?
Thank you in adavance
I’ve had exactly the same issue, the problem I had was that the keypad was wet after heavy rain. I had to take mine apart (carefully!) and dry it with a hairdryer.
I then left it in a warm place to dry out thoroughly for about 6 hours.
I put it back together and it now works perfectly!
  Daitem sc901 au Ketton 1 423 25-11-2025, 01:04 PM
Last Post: GM Techtronics Ltd
  GSM intercom DBElectric 1 5,087 17-06-2022, 12:30 PM
  Daitem gate control novice help needed... TimRW 0 7,298 29-03-2021, 07:58 PM
Last Post: TimRW
  Daitem SC900AX Not Working - Help Please! Eskimo 0 27,763 09-04-2018, 08:04 PM
Last Post: Eskimo
  AES DECT GSM Intercom landline dial programming manchester_sparks 0 18,615 18-03-2018, 09:02 PM
Last Post: manchester_sparks
  Handset system DAITEM D5131GB Carlo 1 41,128 18-01-2017, 10:49 AM
  Daitem D5300 is it compatiable with SC902AU steve redwood 2 28,731 02-01-2015, 02:55 PM
  Daitem D5731gb system royaugout 1 27,641 02-01-2014, 04:15 PM
  Daitem wireless intercom Mel1962 0 22,804 25-07-2013, 12:49 AM
Last Post: Mel1962
  Daitem CTS5200 Controller babypomdiy 1 24,948 16-05-2013, 10:16 AM
Last Post: Blakey111
