  • 18 Vote(s) - 2.67 Average
Bft gate one door stopping
Hello.  I have a pair of gates bft. Motors under the  ground.  One of my gates seem to stop mid way.  The other one is fine.if I gently push it.  It will carry on to close or open.  I've checked the motor and it seems dry and not water damaged.  Been in operation for 12 years now.   Am I right in saying it's the motor needs replacing ?  Just got worn out.
Many thanks in advance.
(12-04-2022, 07:52 PM)Matty c Wrote: Hello.  I have a pair of gates bft. Motors under the  ground.  One of my gates seem to stop mid way.  The other one is fine.if I gently push it.  It will carry on to close or open.  I've checked the motor and it seems dry and not water damaged.  Been in operation for 12 years now.   Am I right in saying it's the motor needs replacing ?  Just got worn out.
Hi Matty,
Thanks for the email,
There are two likely explanations for your issue, one could be if this is a 230v system it could be that the capacitor is on its way out and would likely need replacing, a way of testing this would be to switch over the capacitor and test the motor to see if the fault persists, another plausible issue could be that the motor force on this leaf is not set high enough.
Kind Regards
Hi Matty,
Kind Regards
[quote pid="16553" dateline="1649846569"]
Thanks Joe.   It is a 240 system.    I havnt changed the motor force setting and has been the same for  years and has work faultlessly.   I reckon it must be the capacitor.   Many thanks for your help. Matty
[/quote]
Hi Matty,
Kind Regards
[/quote]
Hi Matty,
Thanks for your response, glad to hear we could be of assistance.
Kind regards,
  SEAV LRX-2186: gate opens a bit then stops mehsom 0 113 10-12-2025, 09:42 AM
Last Post: mehsom
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,048 03-12-2025, 04:18 PM
Last Post: StefanP
  Help me identify this mystery gate opener alpha 5 5,094 23-11-2025, 02:35 AM
Last Post: alpha2
  Peculiar automatic gate behavior Gatefreak 1 5,012 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,637 28-03-2025, 03:15 PM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,189 02-12-2024, 10:40 AM
  Gate not closing thronetm 0 4,169 16-11-2024, 09:25 PM
  Gate kit recommendation electric gate harry 0 3,998 10-09-2024, 03:57 PM
