  • 22 Vote(s) - 3 Average
RCD trip on close LUX 2B
Hi, I have a single LUX 2B running on a Rigel 5 controller. Recently started having issues with it tripping the RCD when on a gate closing cycle. I've replaced the RCD with no luck, motor capacitor has been tested and is all gd. Photocells have been inspected, one did have water ingress, I haven't tested with the photocells disconnected. Starting to think the motor has gone bad, is there anything else I can test/try?
Cheers
Dave  Big Grin
(28-03-2022, 09:10 PM)DP86 Wrote: Hi, I have a single LUX 2B running on a Rigel 5 controller. Recently started having issues with it tripping the RCD when on a gate closing cycle. I've replaced the RCD with no luck, motor capacitor has been tested and is all gd. Photocells have been inspected, one did have water ingress, I haven't tested with the photocells disconnected. Starting to think the motor has gone bad, is there anything else I can test/try?
Cheers
Dave  Big Grin
Hi Dave,
thanks for the message,
this to me sounds like it is either a short on the closing phase of the motor cable or a short on the motor windings which intern could have been caused via water ingress, have you checked the cable at all?
Cheers
Dave  Big Grin
Hi Dave,
Cable and glands all look good, no visible cuts or damage, is it possible to open up and inspect the internals on the Lux2B? (Looks like its a sealed unit for the hydraulic fluid).
I've tested with the photocells disconnected and a jumper wire used in their place, still trips so that rules out the cells.
Cheers,
Dave
Cheers
Dave  Big Grin
Hi Dave,
Cheers,
Dave
Hi Dave,
Thanks for getting back to us,
Unfortunately in this circumstance you cannot really open up the motor due to it being hydraulic and attempting to do so may cause further damage. The issue could lie with the motor or the actual cabling itself and providing the cables are in good condition and there is no shorts between them I would most likely say that the motor has became faulty.
Last Post: jojo351
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,660 17-07-2024, 02:24 PM
  Gate wont close issue MR_ROBOT 3 16,880 11-04-2024, 08:08 AM
  Ecosol/Kustos doesn't open and close fully? supremee 3 7,013 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 3,790 19-01-2024, 09:54 AM
  BFT controlled gates open but don't close MikeJep 5 27,893 04-01-2022, 09:58 AM
  Remote only working close up Uphill 0 5,725 03-10-2021, 07:50 PM
Last Post: Uphill
  Gate won't close on manual or auto Baz1981 0 7,624 23-06-2020, 05:27 PM
Last Post: Baz1981
  BFT Gate won't open or close Steveturbocal 0 12,602 17-11-2019, 11:10 AM
Last Post: Steveturbocal
  BFT two gate system - left side suddenly refuses to close thomasario 1 17,763 16-06-2018, 01:01 PM
