  • 20 Vote(s) - 2.8 Average
NICE MC800 for failed A60 mindy
My A60 mindy failed and I swapped in an MC800.
When I power it up the bluebus LED is giving 7 short flashes with a one second pause. L1 and L2 are on.  The manual indicates the 7 flashes indicates 'Electric circuit anomaly'
While similar the electrical connections on the MC800 are not the same as the A60.
On the M60 there was a separate 'Common' terminal (terminal 20) to the 24vac terminal (terminal 18) but on the MC400 it looks to be combined with the 24vac terminal  (terminal 4).
The two feeds I had from terminal 18 and 20 on the A60 are both connected to terminal 4 on the MC800 and I am wondering if this is correct?
Any insight appreciated.
Cheers
bg
OK found a video on utube with a similar setup to mine (not in English mind you, but a picture is worth a thousand words). And he had the same flashing leds, however he proceeded with the setup and all came good.
So I followed suite and my gate is now working.
bg
(14-06-2022, 10:58 PM)bg148 Wrote: OK found a video on utube with a similar setup to mine (not in English mind you, but a picture is worth a thousand words). And he had the same flashing leds, however he proceeded with the setup and all came good.
bg
Brilliant, great to hear if there are any further issues do not hesitate to contact us.
Kind regards
  Nice Robus closing after photo Nexur 1 7,245 26-08-2025, 01:47 PM
  Nice Control unit passcode removal Andruelectricgates 1 3,598 17-06-2025, 11:25 AM
Last Post: HarrisonN
  MC800 NOT OPENING FOR WHITELISTED PLATES AFTER FACTORY RESET Wenzo 4 3,756 27-05-2025, 09:09 AM
  NICE gates open slightly then stuck Overthefence 2 4,231 21-05-2025, 10:54 AM
Last Post: gatekeeper
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 3,094 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 9,406 10-12-2024, 11:29 AM
