  • 19 Vote(s) - 2.47 Average
PHOBOS N Manual Overide Problem
Hi, I have PHOBOS N motors and I can't get one of the motors to unlock with the key. When I turn the key the nothing happens, on the other motor you can feel it release then it opens. Any help would be appreciated.
(02-12-2022, 04:42 PM)Dazrob Wrote: Hi, I have PHOBOS N motors and I can't get one of the motors to unlock with the key. When I turn the key the nothing happens, on the other motor you can feel it release then it opens. Any help would be appreciated.
Good Morning,
Its more than likely that the manual release mechanism inside is jammed. I would recommend running the gates to different positions automatically then trying to release it. You could also try and put some sort of WD40 if it is stiff. Lastly, try and push the gate back and forth while turning the manual release. It may be that the mechanism is fully seized and needs replacing.
Kindest Regards,
Thanks, Sam. I will try this later.
I tried what you said but it did not release. I can hear the mechanism click when I unlock it but it does not release the arm.
  Bft gate problem djkokalis 1 5,426 14-02-2024, 12:39 PM
  Phobos motor movement erratic Caesium 1 4,000 24-08-2023, 01:39 PM
  BFT opening problem 8 55,702 08-08-2023, 02:14 PM
  LUX G BT 2B not closing properly since manual override swinnie 1 5,011 03-08-2022, 01:44 PM
  Phobos N L BT one leaf won’t open BigJC 0 4,988 11-06-2021, 01:33 PM
Last Post: BigJC
  Phobos reversing after closing Sim75 0 3,962 21-05-2021, 07:04 AM
Last Post: Sim75
Smile Rigel 5 Manual override Stramorebees 0 11,782 20-09-2020, 12:03 PM
Last Post: Stramorebees
  Gate won't close on manual or auto Baz1981 0 7,624 23-06-2020, 05:27 PM
Last Post: Baz1981
  bft hydraulic gate problem richh 4 27,882 23-12-2019, 04:36 PM
  Strange opening problem Baz1981 4 88,512 15-07-2019, 08:39 AM
