  • 24 Vote(s) - 2.71 Average
Q80A Fault Code
I have a Q80A controller for a set of My Shark automated gates.
The Q80A controller is displaying "St" all the time (start operating) even though no remote fobs are being pressed and all external switches (e.g. pedestrian opening) have been disconnected.
I can't seem to find any way to override the error or reset the board. Even with the actual motors disconnected, the board continues to display "St".....
Any information on what to look for or ways to circumnavigate this error gratefully received!
Thanks.
Kev.
(21-01-2023, 04:29 PM)kevcl15@yahoo.co.uk Wrote: Hi,
Thanks.
Kev.
"ST" means that the control panel is receiving a continuous START command,  Make sure that all START controls connect are properly working and correctly wired (N.O. contact). Whatever you have wired into your Start/open command make sure there isnt a short on the cables or on the accessory. I would take the board back to basics and take out all accessories especially anything giving the gate a open command then reintroduce them one by one to see which accessory/cable is causing the issue.
  TC fault code on Q60ar control board Skydive1710 3 9,759 20-11-2023, 03:12 PM
Last Post: NormanY
  FAAC E124 fault 05 allan@amtas.com.au 0 3,462 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,409 26-09-2023, 05:32 AM
Last Post: max666
  Q80A Strange fault. Cannot work it out, if setting or fault? gray 0 3,386 25-06-2022, 08:14 AM
Last Post: gray
  Proteco Aster 3 ram fault soother 2 8,487 14-07-2021, 11:58 PM
Last Post: soother
  Fav sliding gate error code plus other Adam67 0 11,173 02-09-2020, 07:06 PM
Last Post: Adam67
  DAITEM WIRELESS INTERCOM how do I change entry code?? Help! Scarlett 3 28,603 04-05-2018, 07:43 AM
Last Post: Gagobaa
  Changing code at control unit, Mindy A6 /A7 Lynne Woodward 0 7,816 22-10-2016, 07:36 PM
Last Post: Lynne Woodward
  proteco Q60AR fault seb 0 9,019 12-12-2014, 07:41 AM
Last Post: seb
  Proteco Aster Q60A broblem-error code n2 johnkampol 0 9,688 14-09-2014, 11:16 AM
Last Post: johnkampol
