  • 17 Vote(s) - 3.06 Average
gate stop broke - any spares=liftmaster 300
This is a new one for me.  I replaced one of the liftmaster motors a sub 300m with what I thought was a genuine one but is in fact a motor made by IDRO.  Its 12 month since install and yesterday gates were closing but  side on right as you look out was moving about 6 inches farther than left when in the closed position.  I opened the motor covering and found that the gate     stop had broken in half!!  Here are 2 pics.
What would cause it to break so soon? Wrongly fitted or ..
I bought this part from easygates in April 2021 but fitted with new motor April/may 2022.
is it possible to buy a spare?
Also can I place a piece of metal in front of motor arm and use that as a gate stop?
Motor was fitted by a proffessionsal.
bomitie
Hi Bomitie,
it could be that your force is set too high on the motor causing damage to this part.
it also looks like the stop has corroded may be due to water ingress and that could be weakening the part further until it fails.
This isn't a part that we stock individually.
If you would like to email us I can contact LiftMaster to see if this part is something they have and we can sort this over email
Kind Regards
Matt
Hi Matt
Thanks for reply.  I have gone back to where I got that IDRO motor and they have sent a gate stop set i.e one for front and one for rear.  I want to change it myself but the bolt for the front gate stop has a hexagonal head and after trying 3 hardware shops today I cant find the correct type of key, it looks like an alun but a bit different. Here is a pic and would you know name of tool/key required and maybe I can get it online.
After further searching I think its a HEX SOCKET IS BEST is it 8mm or 8.8mm?
As for the rusty state I would say its been broken for quite a while and eventually dropped down.  Boxes are dry and I clean them out every 12 months.  Job was done last May so due this month""
[attachment=441
  SEAV LRX-2186: gate opens a bit then stops mehsom 0 132 10-12-2025, 09:42 AM
Last Post: mehsom
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,087 03-12-2025, 04:18 PM
Last Post: StefanP
  Help me identify this mystery gate opener alpha 5 5,104 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,023 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,018 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,645 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,505 18-03-2025, 06:40 AM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,200 02-12-2024, 10:40 AM
Last Post: bing
  Gate not closing thronetm 0 4,170 16-11-2024, 09:25 PM
Last Post: thronetm
  Gate kit recommendation electric gate harry 0 4,001 10-09-2024, 03:57 PM
