  • 20 Vote(s) - 3.05 Average
Ecosol/Kustos doesn't open and close fully?
I am in Australia and I know Ecosol solar is not common in UK.
I am still giving a try if someone here can help with this.
I am running Ecosol/Kustos set-up.
I finished setting with a jumper on for constant power and it works fine with the jumper on.
However, without jumper it opens and closes only 1/3 of full operation.
What may cause this?
(09-03-2022, 11:51 AM)supremee Wrote: Hi,
Hi ,
I am facing the same issue. Did you find the soltuion?
Have got the solution to it. In logic you will have Aux 0/1/2/3 - make sure the value is 6-gate running ( output active while motors are powered)
Happy to observe this! Awesome ideas and the standard of fine detail distributed is incredible!
Thanks and good day!
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 101,963 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 3,974 03-02-2025, 12:24 PM
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,362 03-02-2025, 11:29 AM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 2,554 04-11-2024, 05:59 PM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 4,661 17-07-2024, 02:24 PM
  Gate wont close issue MR_ROBOT 3 16,882 11-04-2024, 08:08 AM
  Thalia - Photocell Close J to the D 1 3,792 19-01-2024, 09:54 AM
  BFT LUX2B Intermittent failure to open brookkr 4 13,411 07-09-2023, 08:32 AM
  BFT Thalia ‘Hold Open’ hehasmoments 5 13,329 24-08-2023, 01:38 PM
  Set remote to “only open” gate mark123499 4 10,038 30-05-2023, 01:57 PM
Last Post: mark123499
