  • 23 Vote(s) - 3.65 Average
BFT Sliding Gate randomly opening and closing
Hello All,
I have a BFT Deimos sliding gate that when fully closed, will randomly start opening and then stop half way, start closing again, stop before closing, and start opening again.
The gate has worked perfectly fine for a decade, and suddenly started playing up.
I have replaced the photocells, both entry and exit pin pads, gate motor and board. I have also tried using the autoset function so the gate can relearn itself, however the problem still happens right away afterwards.
Open to all suggestions, I'm at a loss as to why this would suddenly start happening, Please help!
Hi Adrian,
Have you disconnected all accessories from the board such as push button, intercom, keypads?
I would disconnect all accessories from the board just in case one of these are causing the issue.
Mike
(12-02-2024, 12:48 PM)AdrianMate Wrote: Hello All,
Did u ever fix this issue ?
My gates are doing the same. We have the right side as pedestrian and then both can open together to let cars in/out the driveway.
The pedestrian side opens by itself then goes back and forth. After it does this, the intercom won't work to open the pedestrian side, or the manual press-to-exit button, but the remote controls do still work.
I have replaced the intercom receiver module as the old one was corroded. I can get it all working well after turning fully off/on etc, then after a few minutes it will just do it by itself again.
Any ideas what would be causing this?
Just an update for everyone as I completely forgot about this post.
I ended up replacing the control board (motherboard) and it works perfectly fine again, the old board for some unlucky reason was just playing silly and must've got slightly corrupted during a power surge/outage (that's just my guess)
To answer some other questions, Yes I did disconnect every accessories adding each back one at a time, I tried replacing everything apart of the system that I thought could be the problem until for some reason I got suspicious about the control board
(05-06-2024, 11:14 AM)AdrianMate Wrote: Just an update for everyone as I completely forgot about this post.
Hi Adrian,
thanks for the update.
take care.
  BFT Gate Motor - Not working elyoussef.ali 0 181 Yesterday, 07:19 AM
Last Post: elyoussef.ali
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 479 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 99,299 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 2,253 03-02-2025, 12:24 PM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 1,339 04-11-2024, 05:59 PM
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 3,137 15-10-2024, 10:37 AM
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 2,978 17-07-2024, 02:24 PM
  Gate radio receiver not working Zhymke 0 1,848 23-05-2024, 06:35 PM
Last Post: Zhymke
  Gate wont close issue MR_ROBOT 3 14,967 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 4,342 14-02-2024, 12:39 PM
