  • 42 Vote(s) - 2.81 Average
#21
Hello
(15-05-2023, 11:25 AM)Nemen3242 Wrote: Hello
Basically, I connected a hikvision relay DS-PM1-O1L-WE to the SBS contacts, I power the relay via STOP and PP as shown in the manual.  I do not understand why the opening works when I close the relay via the Hikvision AX Pro where the relay is enrolled, but it only close half a meter or something and than goes to full open again. I tried all settings in advanced settings for SBS (Open - Close - Open - Close etc) to no availability.
Thank you!
Thank you!
Try this. This should also help https://www.shelly.com/en-gb/products/pr...lly-plus-1
Thank you!
Thank you!
I didn't need to try because my other method worked (with access controller). But this should also work. Buy it from amazon, if it doesn't work, you just return it.
Thank you!
Thanks so I did a little experiment, and I think I solved out all this dilemma! I connected a wire between the SBS contacts, for the opening it worked fine, and also for the closing. Then what I did next was to keep the wire there for a several seconds. Boom, the closing has the same bad behavior. My Hikvision relay pulse default was 5s for pulse, hence the issues! I lowered that to 2s, all works fine! I'm 100% you had the same issue initially going from the Hikvision door station directly to the Nice. I know because I had to replace an older Nice600, not robus, and that door station relay worked fine!
Now we can put this to rest. No need for any access control. Regardless thanks, your replay made me think twice about certain things...
(10-05-2024, 03:47 PM)P100D Wrote: Hello! Could someone please help me with this? I have the exact same issue, however I don't have a hikvision access control unit and have no intention to buy one.
Thank you!
The logic seams right. My assumption was that it was the voltage. Perhaps it was the duration. When i changed the triggering device, probably the duration also changed as a side affect and made the problem go away.
(10-05-2024, 04:35 PM)Nemen3242 Wrote: Try this. This should also help https://www.shelly.com/en-gb/products/pr...lly-plus-1
It is the duration trust me. And yes for how it got fixed for you. I posted another thread on how to program the remote, any idea?
(10-05-2024, 05:19 PM)Nemen3242 Wrote: I didn't need to try because my other method worked (with access controller). But this should also work. Buy it from amazon, if it doesn't work, you just return it.
I don't know unfortunately
HikNOvision in their infinite wisdom (or lack of it) upgraded the sw and fw, and the new release (1.3.0) has the pulse minimum only 5sec, which means their relays no longer work with the NICE gates.
  SEAV LRX-2186: gate opens a bit then stops mehsom 0 106 10-12-2025, 09:42 AM
Last Post: mehsom
  Help me identify this mystery gate opener alpha 5 5,081 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,007 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,004 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,631 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,496 18-03-2025, 06:40 AM
  Nice wingo 5400 and MC800 engrbhadz 0 2,183 18-03-2025, 05:53 AM
Last Post: engrbhadz
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,167 02-12-2024, 10:40 AM
Last Post: bing
  Gate not closing thronetm 0 4,165 16-11-2024, 09:25 PM
Last Post: thronetm
  Robus Not Operating AlanWhite 3 16,771 11-09-2024, 05:00 AM
Last Post: Lee Zhang
