  • 15 Vote(s) - 3.8 Average
BFT Rigel 5 - Phot message
I have a Rigel 5 , and it’s coming up with a message Phot
The gate has , 2 x in ground car detectors , photo cell, 2 wire gate keypad, and safety bar FLC 8K2.
The cabinet for the controller was rotten, so I labelled every wire , and transferred to another metal cabinet.
I had a minor issue , it poured with rain and a few labels came off, but I am pretty sure I put them back where they came.
On powering up, the gate stays open, I see an Open message then Phot.
I have tried removing the photo cell connectors 52 and 55, but I then get Phcl.
I have tried bridging 52 and 55 to bypass the photo cell and I still get Phot.
I have given up trying to fault find tonight, a head torch in the rain isn’t great.
Does anyone have any ideas? Or even suggested fault finding process .
Photo of setup attached ( my plan was to tidy and re label when it was daylight dry!)
Rob
(27-10-2024, 10:04 PM)robs999 Wrote: Hi
Rob
Hi Rob,
Thank you for your email.
I would recommend also bridging 35 and 36, as I believe this is actually the input that is causing your issue. More than likely if you have photocells on your system, the cable has either broken or the cells have become misaligned overtime or a faulty cell. However providing this bridge will hopefully allow us to rule this out.
Rob
Hi Rob,
Jackpot! that did it, i found a loose wire.
Thanks so much!
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 99,312 21-07-2025, 06:54 AM
Last Post: jojo351
  BFT Altair-P "Phot" message. How to bypass/Test? AdamC 0 363 16-07-2025, 06:36 PM
Last Post: AdamC
  BFT Rigel 5 Talonfinger 0 1,106 26-03-2025, 12:07 PM
Last Post: Talonfinger
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 1,846 03-02-2025, 11:29 AM
  Stressing over BFT Rigel 6 Help please Vaf888 3 3,197 30-10-2024, 12:54 PM
Last Post: Vaf888
  BFT Rigel 5 issue Adamit 0 1,738 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 16,365 04-05-2024, 12:47 PM
Last Post: Alee
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 4,021 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 3,075 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 5,993 05-01-2023, 11:53 AM
