  • 18 Vote(s) - 2.94 Average
CAME F7000 Gate Openers Issue
Hi All, this forum is always so helpful and hoping for a fix once again so, fingers crossed.
Thanks in advance,
Jack
Thanks in advance,
Jack
Hi Jack,
Hi Jake,
Really appreciate your response. I don't have any photocells connected, in fact I have disconnected everything external including the antenna for the remote to check if there was a problem there. Despite everything being connected, it is still constantly flashing the red light like it is receiving a signal. When I do connect, even when I link in 7&2 directly, I don't get any relay click and nothing springs into action. I purchased another PCB just in case and swapped it over, but this one has the same issue and the red light remains constant.
Thanks,
Jack
Thanks,
Jack
Hi Jack,
  CAME sliding gate drops codes after power outage Catch 1 5,290 02-03-2023, 03:18 PM
  Link Came F7000 gate openers to Enterview 3 Intercom Jackolantern 2 13,100 23-04-2020, 07:11 PM
Last Post: Luke Scott
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 20,164 02-05-2018, 06:18 PM
  Came sliding gate sticking on opening Jellybean 0 10,986 02-07-2016, 06:53 PM
Last Post: Jellybean
  Came gate opening adjustments TobagoGate 0 28,878 20-12-2012, 02:40 PM
Last Post: TobagoGate
