  • 303 Vote(s) - 2.9 Average
I've posted this in BFT as well but there is also a general question.
Thanks in advance
.pdf   SUb.pdf (Size: 57.98 KB / Downloads: 1,337)
Thanks for the reply, I've just removed the lid and the pump is marked Sub R. Now looking at the spec sheet for Subs it says these are suitable for up tp 1.50m, our gate leafs are 2.5, though I don't think they will weigh any where near 800kg. Is this critical ?
Thanks once again
The legnth of the leaf is very important. For the size of each leaf being 2.5m you would require the SUB ER motors. The boxes you have already installed would be compatible. The SUB ER motors will be quite alot slower than the SUB R motors. They are also non-locking so security will be an issue as you can force the gates open.
With these non-locking motors, the seals will not break and should last a long time with regular service.
We can get these motors ordered in for you if you require them
If you need any more details please call us on 0845 054 50 70 and ask for Technical.
(13-04-2010, 06:44 PM)jgpp Wrote: Thanks for the reply, I've just removed the lid and the pump is marked Sub R. Now looking at the spec sheet for Subs it says these are suitable for up tp 1.50m, our gate leafs are 2.5, though I don't think they will weigh any where near 800kg. Is this critical ?
Thanks once again
  Help me identify this mystery gate opener alpha 4 1,657 11-08-2025, 03:42 PM
  Peculiar automatic gate behavior Gatefreak 1 2,619 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 2,426 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 2,439 18-03-2025, 06:40 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 29 47,365 27-02-2025, 03:08 PM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 8,278 02-12-2024, 10:40 AM
  Gate not closing thronetm 0 3,343 16-11-2024, 09:25 PM
  Gate kit recommendation electric gate harry 0 3,048 10-09-2024, 03:57 PM
  Recommended automatic gate opener? drewdavis 0 3,445 28-08-2024, 05:13 AM
Last Post: drewdavis
  Trying to identify this Gate Controller - HOCHE UC109? RossAM 0 3,393 02-08-2024, 04:47 PM
Last Post: RossAM
