  • 252 Vote(s) - 2.88 Average
p7 -45 Ram and Rigal 5
Hi, can any one help.
I have a Rigel 5 control box with p7-45 Ram.
All was well, then the control box came up with a error of ER11.
I phoned BFT and they said bad connection or something going to ground.
If it is the Ram, does anybody know how to check this or get the Ram repaired.
Smile
The only thing I could recommend would be to start removing devices which has been hard wired into the control panel until the fault clears. Once you have located the problematic device, I would recommend tracing all wiring and make sure there are no shorts. I'd imagine if the arm were damaged internally, there's not a lot you can do other than replace it!
Kindest regards,
Dave
(11-07-2013, 07:16 PM)d309 Wrote: Hi, can any one help.
Smile
many thanks the only thing connect is the ram so i have taken out of the loop and the control box comes up with er16 witch is the motor not connected thanks
(12-07-2013, 01:42 PM)Blakey111 Wrote: The only thing I could recommend would be to start removing devices which has been hard wired into the control panel until the fault clears. Once you have located the problematic device, I would recommend tracing all wiring and make sure there are no shorts. I'd imagine if the arm were damaged internally, there's not a lot you can do other than replace it!
Kindest regards,
Dave
Smile
