  • 310 Vote(s) - 2.86 Average
NR error code
I have a Proteco Q60A installed in my house. Few days ago I had to power down my gates, since then it is showing error code NR. But I don't think there is any fault with the motors.
I had increased the torque on the board but no joy.
Any help please?
Thanks and Regards
Bara
Hi Bara,
This is indicating it cannot detect either of your motors. Have you had them disengaged by chance? If so, try re-engaging them and do a reset on the board by powering down and back up again to clear the diagnostic. I have attached the Q60A manual which has the full list of diagnostic error codes on page 30 onwards.
Kindest Regards,
Dave - Technical Staff
(26-09-2013, 08:43 AM)Bara Wrote: Hello,
Any help please?
Thanks and Regards
Bara
.pdf   Q60AR Control Board - Single Swing Gates.pdf (Size: 1.89 MB / Downloads: 3,471)
Hello Dave,
Thanks for the response. I powered down, re engaged but still the problem is there. Normally the display shows in stand by mode '- -' when it receives signal from fob it turns to 'Go' then briefly 'NR' appears and comes back to '- -' [This was the original problem]
I solved this now. May be someone else will find this posting useful.
I disengaged both the motors and engaged them. Closed fully manually, re engaged again (note my gates engaged only half way through) powered up.
Works again as it should.
Thanks for all your help here in the forum and in Proteco.
Bara
  Thalia P - BAR error devsolo 3 17,945 03-02-2025, 09:57 AM
  BFT Thalia “bAr” error. Joel23M 1 5,035 17-01-2025, 10:06 AM
  TC fault code on Q60ar control board Skydive1710 3 9,765 20-11-2023, 03:12 PM
Last Post: NormanY
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,417 26-09-2023, 05:32 AM
Last Post: max666
  Q80A Fault Code kevcl15@yahoo.co.uk 1 5,585 03-02-2023, 12:00 PM
  Proteco Q60 - FH error then close after opening Needlerp 1 5,882 24-06-2022, 09:54 AM
  Deimos BT 400/600 error codes orange 0 5,958 07-12-2020, 09:36 AM
Last Post: orange
  Fav sliding gate error code plus other Adam67 0 11,182 02-09-2020, 07:06 PM
Last Post: Adam67
  Re: Error 30 tony.jay8 2 14,838 10-05-2018, 11:17 PM
Last Post: tony.jay8
  DAITEM WIRELESS INTERCOM how do I change entry code?? Help! Scarlett 3 28,619 04-05-2018, 07:43 AM
Last Post: Gagobaa
