  • 307 Vote(s) - 2.79 Average
RPM Reversal Diagnostic Error on Liftmaster LYN40024
I have been getting the diagnostic error "RPM Reserval" all the time and i do not know how to rectify this problem. The gate will not close or open properly. I have tried resetting the limits many times and the gates will bounce back after it has been opend or closed.
Does the setup allow you to set the limits by holding the direction buttons or does it move a few inches then stop during the limit setup ? If it does then RPM sensor is gone in the motor most likely due to wires being shorted. If Not then most likely brackets are incorrect and arm has strained the gears inside causing it to fight against itself.
(16-05-2011, 03:53 PM)Mark Wrote: Does the setup allow you to set the limits by holding the direction buttons or does it move a few inches then stop during the limit setup ? If it does then RPM sensor is gone in the motor most likely due to wires being shorted. If Not then most likely brackets are incorrect and arm has strained the gears inside causing it to fight against itself.
The setup allow me to set the limits by holding the direction buttons with no problem and the limits are set propoerly. However, after saving, either on closing or opening the gate will not stop and bounce back and give the RPM reversal error. Sometimes after trying a few times, the limits will not be set and i have to disconnect the system for a good number of hours and try it again, then the limit will be set but the gate will not work properly. Please advise what else i can do.
  Liftmaster MYQ Internet gateway koen_dc 4 26,319 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  Liftmaster LA400 Defender 6 21,310 03-08-2023, 12:26 PM
Last Post: Torantrieb
  odd liftmaster scs300-24 scopie88 3 20,761 13-04-2022, 10:20 AM
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 18,810 09-03-2021, 02:46 PM
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 22,895 22-02-2021, 08:48 PM
Last Post: russ
  Liftmaster CB1 gates started to open themselves telnet123 4 34,662 01-01-2020, 09:43 AM
Last Post: pronosoft
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 35,247 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  Liftmaster sliding gate Kar1e 1 19,832 08-08-2017, 11:23 AM
  Liftmaster SCS300K - stop/go mtuk100 1 18,140 18-04-2017, 09:31 AM
  La412 RPM reversal error winter5470 0 7,264 28-09-2016, 01:18 PM
Last Post: winter5470
