  • 309 Vote(s) - 2.82 Average
Gate closing but not opening
Question
Hi, I have a BFT Sliding Automatic gate with Deimos motor using Mitto fobs for remote opening / closing. Installed about 5 years ago. Gate is opening but not closing. It moves about 6 inches back to close and then gets stuck ? What should I check or look for please ? Simple instructions please I'm a woman ! ALL advice very Smile welcome.
9 times out of 10 this kind of problem is down to one of the safety inputs i.e. photocells, disabling the control panel from operating. First thing to do is check the relay photocells, and that you can hear the relay tick when you pass your hand in front of the infra red beam. If you do not hear a tick, then the chances are that the relay is already being held open down to either a damaged cell or a build up of muck in the lens cover.
If you find to have faulty cells, then it is recommended to replace these asap. You can find an ideal replacement set at the following address:
http://easygates.co.uk/product_info.asp?ProductID=136
If this test does not prove to be successful, then you will need to take a look at the control panel and run through the diagnostics from the manual on there to see if there is anything else affecting the system.
Kindest Regards,
Dave
(11-06-2014, 11:17 PM)CAROL Wrote: Hi, I have a BFT Sliding Automatic gate with Deimos motor using Mitto fobs for remote opening / closing. Installed about 5 years ago. Gate is opening but not closing. It moves about 6 inches back to close and then gets stuck ? What should I check or look for please ? Simple instructions please I'm a woman ! ALL advice very Smile welcome.
Dave Blake
Thank you Dave. Will try and let you know.
(12-06-2014, 09:26 AM)Blakey111 Wrote: Hi,
Kindest Regards,
Dave
Hi Dave
Problem solved. It was the spring that was disengaging from the bent "arm"....thank you for your help...Smile
Kindest Regards,
Dave
  BFT Gate Motor - Not working elyoussef.ali 0 436 27-08-2025, 07:19 AM
Last Post: elyoussef.ali
  Can I pair these BFT fobs with my CAME gate? cgfw201 1 525 11-08-2025, 04:12 PM
  BFT Rigel 5--how to set swing gate slow close at end ? jojo351 3 99,359 21-07-2025, 06:54 AM
Last Post: jojo351
Exclamation Thalia Light btl2 new gate openers only open gate Libwala 2 2,282 03-02-2025, 12:24 PM
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 1,371 04-11-2024, 05:59 PM
Last Post: Sootylfc
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 3,190 15-10-2024, 10:37 AM
Last Post: Sootylfc
  BFT LUX G BT 2B gate won't open or close fully PaulR 1 3,004 17-07-2024, 02:24 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 5 8,677 14-06-2024, 12:12 PM
  Gate radio receiver not working Zhymke 0 1,868 23-05-2024, 06:35 PM
Last Post: Zhymke
  Gate wont close issue MR_ROBOT 3 15,007 11-04-2024, 08:08 AM
