  • 267 Vote(s) - 2.61 Average
Gate remotes stopped working
Hi there, first time poster.
I have a Liftmaster 500 electric gate motor with I think failsafe photocells.
We went away over the weekend and come back, the remotes are no longer working.
Checked the CB22 circuit board and open and close led's are flashing red which seems to indicate photocell problem which tallies with the troubleshooting guide in the manual.
Now the remotes are still working because I pulled out the photocell plug on the CB22 and got them to relearn which they did.
Ive check the connections each end on the photocells with no issues.
Have the photocells developed a fault or is the circuit board having a moment?
Any ideas?
Thanks in advance
If the LED's on the board are flashing then this does not indicate a photocell fault. The Diagnosis for photocells is as follows:
LED Flashing: No photocell connected to relevant circuit. Circuit OK.
LED OFF: Photocells connected. Circuit OK.
LED ON RED: Photocells connected, Problem with photocells. Check for obstacle blocking infra red beam, Check lens covers, check wiring.
If you could check the above diagnostics on your control panel, we can determine from here what the problem may be. If everything appears ok on the circuit board, then it may be eith interference in the area affecting the range on your remote's. Or it could be the radio board located on the right hand side of the control panel, which has failed.
Hope this has helped.
Kindest Regards,
Dave
(08-12-2014, 02:29 PM)Steviev1 Wrote: Hi there, first time poster.
Any ideas?
Thanks in advance
Dave Blake
  SEAV LRX-2186: gate opens a bit then stops mehsom 0 121 10-12-2025, 09:42 AM
Last Post: mehsom
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,060 03-12-2025, 04:18 PM
Last Post: StefanP
  Help me identify this mystery gate opener alpha 5 5,096 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 2,015 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 5,014 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,638 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,504 18-03-2025, 06:40 AM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,191 02-12-2024, 10:40 AM
  Gate not closing thronetm 0 4,169 16-11-2024, 09:25 PM
  Gate kit recommendation electric gate harry 0 3,999 10-09-2024, 03:57 PM
