  • 211 Vote(s) - 2.69 Average
NICE Toona Ram Problem
Good morning folks,
I hope you may be able to help me with a gate problem I have.
I have a pair of driveway gates operated by NICE Toona rams and one gate opens but doesn't stop and reaches its return point and causes both gates to close. When this problem appeared I was going to unlock the gates and leave them open but discovered the gate with the opening problem wouldn't unlock and the "clutch or differential" between the motor worm and drive worm is seized and won't release/decouple.
I'd like to know where I can get a replacement part so as to at least be able to use the unlock facility and open the gate if need be? I guess the second question is, is this likely to be the cause of the gate travel to the end stop problem I have in your experience?
Any help much appreciated.
(02-08-2015, 09:28 AM)aptid Wrote: Good morning folks,
Hello
Under the ram itself is the mechanical stop still in place? this may have moved and may need re programming.
Cheers Sav,
I need to replace the clutch/differential which is on Order from Nice and I will check when I open it up.
Many thanksCool
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,048 03-12-2025, 04:18 PM
Last Post: StefanP
Last Post: engrbhadz
  Program a 3rd party remote to Nice Robus N600 P100D 4 8,746 13-05-2024, 03:36 PM
  Nice MC824H gate stuck open Markp80 1 5,736 13-05-2024, 02:32 PM
  Photocell Problem marcoos_1 4 28,250 04-01-2024, 10:23 AM
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 8,674 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 7,871 24-08-2023, 01:34 PM
  Nice Moonbus Photocells - Faulty? ddaddy 2 6,604 11-07-2023, 01:33 PM
  Nice HS400 Andruelectricgates 0 2,645 09-06-2023, 09:28 PM
Last Post: Andruelectricgates
