  • 95 Vote(s) - 2.94 Average
How to program new universal control to work with FAAC receiver
Hi Guys,
I already passed three days on the following problem, so hopefully one of you many have the solution.
Environment:
FAAC Gate;
Main PCB = 450 MPS Control panel
Receiver = FAAC RP 433 ESL
Remote Control (transmitter) = TML2 433 ESL
- This FAAC gate tx/rx uses fixed code, 433.92Mhz
- The gate and the original remote control fully function
- The security jumber LK1 has not been removed in the original FAAC remote control
Ref to: http://www.faac.fr/uploads/media/PLUS_433_multi.pdf
As I only have one Remote control and now have teenage daughters who drive, after seeing some how-to videos on youtube (inc this one https://www.youtube.com/watch?v=DbUbKXvKUb4), I purchased six # universal remote controls on ebay.
(From all the youtube video I have seen the model I have is very popular examples
https://www.youtube.com/watch?v=DVljEZWxFAM
https://www.youtube.com/watch?v=QyzZXeKUXlE
The problem are:
- After following the A&B clear memory procedure, - the six remote control ‘seem’ to have successfully received the code from the working FAAC remote control. (Or at least the LED on the new remotes say they are programmed).
- The problem is none of the newly programed remotes fail to open the gate or turn on the LED in the ‘FAAC RP 433 ESL’ as the original does.
(As an extra step - assuming the remotes are programmed correctly, I also followed the official step 5.2 procedure in this FAAC pdf (http://www.faac.fr/uploads/media/PLUS_433_multi.pdf). However the FAAC received failed to do anything/did not detect the new remotes.
Thus I am a little stuck;
Assuming that all six new universal remotes are not duds and also assuming that the FAAC RP 443 ESL will/should work with universal remotes controls of this type;
Can anyone tell me the correct procedure to get a universal remote control to work with a FAAC RP 443 ESL receiver?
Thank you for your help,
Brgds
Denis
If you have purchased universal remote controls off ebay, im guessing they are silver and black with a red led when the button is pressed. Technology in the remote known has rolling code. These remotes are not reliable and cannot clone every remote on the market. You will probably find they are not compatible. When buying new remotes for a Faac system you will be better buying the original remotes as they are reliable and guaranteed to work.
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 5,699 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,336 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,066 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,006 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,774 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,399 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,409 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,133 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,780 13-11-2023, 11:58 AM
Last Post: LoneStarCycler
