  • 216 Vote(s) - 2.86 Average
Dieffematic EKOS 24 M2 - Battery backup
Fitting a Dieffematic 24V gate system where battery backup is required. Using the EKOS 24 M2 controller with GTM 24 rams.
There is an instruction manual that comes with the panel - in Italian - which we have translated, and it tells us that there is a 33V 250mA supply output on terminals 25 + 26 on the board for connection to a battery charger module. And that's it. No actual recommendation or pointers to what battery charger module can be used.
So, looking at some advice on suitable Battery Charger modules for use on this system and some pointers on connections (obviously the 33V is a feed to the module, and guessing there is a power collapsible switched 24V power output - from batteries - on loss of panel power via a relay or something).
P.S: Rams have limit switches, so require system suitable for LS ram version
.pdf   EKOS24M2_page1.pdf (Size: 546.42 KB / Downloads: 1,103)
