11-01-2017, 09:05 PM
Hi my gates stopped opening. Error code is n1 motor problem (Q60A/R)control unit.checked fuses and capacitor where can I look from here.thanks in advance
Q60A/R motor problem
12-01-2017, 07:35 AM
(11-01-2017, 09:05 PM)Johnmc Wrote: Hi my gates stopped opening. Error code is n1 motor problem (Q60A/R)control unit.checked fuses and capacitor where can I look from here.thanks in advance hi you can check engine rezistance or even powered engine up by 230v bypassing control board . regards Best Regards
Tom
12-01-2017, 06:02 PM
hi bypassed main board and powered up no movement from motor . Am I looking at replacing the motor.
12-01-2017, 09:08 PM
(12-01-2017, 06:02 PM)Johnmc Wrote: hi bypassed main board and powered up no movement from motor . Am I looking at replacing the motor. hi have you got some motor picture , label with tech data regards Best Regards
Tom
13-01-2017, 10:03 PM
did you check motor rezistance ?
did the motor make any noice when was powered up . ? regards Best Regards
Tom
14-01-2017, 06:20 PM
Hi checked resistance all ok ,when I press the fob the relay clicks and the motor turns for a second and cuts out error code n1 appears
14-01-2017, 09:56 PM
what happened when you bypassed control board ? to start only motor direct from 220 power source you have use capacitor too ,did you ? Best Regards
Tom
15-01-2017, 11:33 AM
Hi. This time I did use capacitor the motor turned fine smooth no effort to open gate. Hope this sheads some light
16-01-2017, 08:03 AM
(This post was last modified: 16-01-2017, 08:11 AM by Automatic-TC.)
(15-01-2017, 11:33 AM)Johnmc Wrote: Hi. This time I did use capacitor the motor turned fine smooth no effort to open gate. Hope this sheads some light hi if motor turned in both diretions we know its fine. try opening your gate manualy by your hands there could by some mechanical problem with motor bracket or gate Best Regards
Tom
« Next Oldest | Next Newest »
| Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help | j1000 | 30 | 59,123 |
03-12-2025, 04:18 PM Last Post: StefanP |
| q60a | stevea | 1 | 2,511 |
23-08-2024, 12:14 PM Last Post: stevea |
| Photocell Problem | marcoos_1 | 4 | 28,276 |
04-01-2024, 10:23 AM Last Post: JoeF |
| Proteco Advantage (Q60A) Error Code "03" | CLAUDIOTX | 3 | 23,422 |
26-09-2023, 05:32 AM Last Post: max666 |
Proteco Q60A stopped working | xCO | 0 | 3,363 |
19-06-2023, 01:03 PM Last Post: xCO |
| Replacement Q60A board? | ndyhzlwd | 1 | 5,622 |
10-02-2023, 03:19 PM Last Post: SamA |
| Nice motor | Vandamme911 | 1 | 5,008 |
01-12-2022, 10:31 AM Last Post: JoeF |
| Beninca bob motor wiring to board | Ranch2 | 6 | 13,165 |
18-11-2022, 09:59 AM Last Post: SamA |
| Hello - Another Proteco Q60A/R Question! | SawboMan | 2 | 7,477 |
12-07-2022, 11:48 AM Last Post: SamA |
| proteco q60a microcontroller program | arashkhan | 1 | 5,592 |
17-06-2022, 01:29 PM Last Post: benbrooks |
