  • 180 Vote(s) - 2.98 Average
LED on control board is off
Hoping someone can help. I've replaced and installed a new set of photocells on my BFT Deimos bt gate.
Then turn on the power, but it doesn't work, as the LED display on the control board is off. The LED display was working before I've installed a new set of photocells.
I've checked the main fuse and power wire connections with a multimeter that there is no open circuit.
Any suggestions on how to fix this LED fault?
Thank you in advance for any help.
Arthur
(07-07-2017, 02:44 PM)Arthur_k99 Wrote: Hi,
Arthur
Hi Arthur, I wonder if you had any luck with this? We have exactly the same problem! Thanks so much for any advice you can offer
You may need to check the integrity of the cabling. Either by running new fly leads cabled directly to the photocells from control panel to the photocells for testing purposes only and checking if this cures the problem.
  BFT deimos smoke from board stanli200188 1 4,076 05-03-2024, 04:17 PM
  Thalia P - Wireless control board module mathewnorris22 1 6,529 02-03-2023, 03:17 PM
  Er 10 code on RIGEL 6 control unit Eddiew 1 7,002 05-01-2023, 11:53 AM
  BFT Aires P Board burned Anomalia 0 8,452 15-02-2018, 10:53 PM
Last Post: Anomalia
  BFT LIBRA CONTROL PANEL neilskeates@gmail.com 7 31,562 16-01-2018, 05:13 PM
  BFT Deimos A600 (HAMAL control board) troubleshooting EnricoTerni63 1 19,874 23-12-2017, 05:38 AM
Last Post: TAOZ
  Peccinin remotes with BFT control boards lemafla 0 7,346 09-01-2017, 09:49 PM
Last Post: lemafla
  Remote control never detected by Rigel 5 guyvaio 0 8,282 18-06-2016, 06:17 PM
Last Post: guyvaio
  connect Remote control to Arduino dentalan 4 27,609 30-12-2013, 09:17 PM
Last Post: tommysharp
  bft reigel 5 wireing of motors to control panel declanfay 1 13,719 09-05-2011, 09:45 AM
Last Post: Mark
