  • 180 Vote(s) - 2.99 Average
BFT Icaro N F "ER 38" error?
Hi there guys,
I have a gate that is controlled by a BFT Icaro N F controller.
When the button is pressed on the wireless remote control, the gate moves out but then gets 3/4 of the way across the road and then slows down and then starts coming back.
I see the error on the LED screen saying "ER 38"
Anyone have a guide for programming this controller and a list of error codes?
Thanks for your help,
Dan
Hi Dan,
The error code ER38 refers to slowdown closing obstacle detection, hope this helps.
Tim
Thanks for your help Tim, I can see this in the manual now.
It says "Amperostop" so I presume that the controller is detecting the current going high and reversing.
Since there is nothing in the way I guess I may have a tight spot that I need to check out.
Do you know if there are any parameters to check for the motor current?
BFT Icaro N used impact reaction "D-track" when The weight of the gate is larger than the motor it will coming back, you have to change the motor higher.
ICARO NF used 230 V for slidng gate up to 1000kg or 2000kg. So your gate maybe too heavy.
If you live in VietNam can contact with my company to repair it. https://automaticdoor.vn/cong-tu-dong-bft/
  bft deimos ultra bt600 error f1 pfloyd 4 7,998 04-10-2024, 03:36 PM
Last Post: pfloyd
  BFT Deimos BT A600 fault Error 10 Airbus330/300 5 15,062 06-03-2024, 11:59 AM
Last Post: GateOpe
  thalia error code 3h 35/37/38 detritus 1 6,031 05-01-2023, 11:54 AM
  Lux/Thalia P ersl error Dava12 0 4,772 13-12-2021, 09:35 PM
Last Post: Dava12
  ICARO + LEO B CBB : 12V power for keypad? tommysharp 5 28,196 17-02-2020, 02:24 PM
Last Post: Caesium
  ERROR 11 TheoLouloudis 0 11,716 10-09-2019, 08:52 PM
Last Post: TheoLouloudis
  BFT ICARO Autoset Fail ybkang 0 9,011 20-03-2015, 01:39 PM
Last Post: ybkang
  ICARO + LEO B CBB : Open gate at certain times? tommysharp 2 20,104 17-01-2014, 12:48 PM
Last Post: thm
  ICARO + LEO B CBB : Hard wired push to exit button? tommysharp 2 16,810 09-01-2014, 10:39 AM
Last Post: tommysharp
  BFT Icaro Wiring, photocells, safety edge markeymark 2 22,011 12-01-2012, 11:32 AM
Last Post: sebabastek
