  • 132 Vote(s) - 3.03 Average
Bft gates (im not technical)
Evening all.
I found this forum through a search and am hoping you will be able to help me.
I have a set of bft gates which will not open or close.  Having done some reading I think it could be a photocell not working.
My question is that should all photocells click when the beam is broken?  The ones infront of the gates do, but at the back do not.
Any help.would be greatly appreciated
Chris
Hi Chris,
Thank you for your enquiry, the click that can be heard when a photocell beam has been broken is a relay that changes from N/O to closed or N/C to open. If the second set of photocells aren't doing this then i would advise you to check the photocells are correctly aligned, then check the voltage to the photocells then a continuity test of the cabling being used back to the control board. In past experiance i would of thought it will be aliment or voltage issue. If this still doesn't fix the problem feel free to contact us again.
Kind Regards
Tim
  FAAC GATES NOT CLOSING Slick19000 0 5,341 21-07-2021, 01:45 PM
Last Post: Slick19000
  Hi All BFT ALTAIR-P gates not closing michaelo76 0 6,871 13-08-2018, 05:47 PM
Last Post: michaelo76
  Just found you my gates are stuck open bomitie 1 10,034 30-04-2018, 01:56 PM
Last Post: Tim
  Failure of Swing Gates to Close Auto A C John 1 11,689 28-09-2016, 09:23 PM
Last Post: MWJONES
Wink Geniss Gates with Genius BRAIN 03 Control Board 4LPS 3 22,285 10-08-2015, 09:31 PM
Last Post: 4LPS
