  • 188 Vote(s) - 2.81 Average
Gate Controls/Indicators 200m from Gates
2) Gate open light (240v)
Morning!
I hope this helps.
EasyGates.co.uk
EG Direct - Trade only
Thanks Ryan.
The other problem we have is that the gate is out of sight from the house from  Although it's only 200m in a straight line, it is roughly a 500m walk to get from the house to a point where you can see whether the gate is open or not.
That is quite a distance.
I agree with you mate, it will be difficult to get a strong signal with that distance
Hi, have you possibly tried using a designated Ariel to boost signal strength.
#9
#10
  Help me identify this mystery gate opener alpha 4 1,657 11-08-2025, 03:42 PM
  Gates not staying open JimM169 1 1,228 21-05-2025, 02:55 PM
  Peculiar automatic gate behavior Gatefreak 1 2,619 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 2,426 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 2,439 18-03-2025, 06:40 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 29 47,365 27-02-2025, 03:08 PM
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 8,278 02-12-2024, 10:40 AM
  Gate not closing thronetm 0 3,343 16-11-2024, 09:25 PM
  Gate kit recommendation electric gate harry 0 3,048 10-09-2024, 03:57 PM
  Recommended automatic gate opener? drewdavis 0 3,445 28-08-2024, 05:13 AM
Last Post: drewdavis
