  • 533 Vote(s) - 2.96 Average
Remote Control
David Brisland Wrote:did you get this problem solved as i am having exactly the same problem
Hi, Make sure the radio card is connected correctly and all pins are connected. Try taking it out and re-inserting it just to make sure you have it plugged in correctly.
Have you tried another remote control? Or replaced the batteries in the one you are using?
Have you set up the photocells? you do this by turning the power off, placing a jumper over the terminals labelled "Save Fail Safe Photocells", then turning the power back on and removing the jumper after 15 seconds.
Hope this helps,
Remote Control - by Steve - 08-12-2008, 04:49 PM
RE: Remote Control - by Mark - 09-12-2008, 01:21 PM
RE: Remote Control - by Steve - 09-12-2008, 01:54 PM
RE: Remote Control - by Golfmadnut - 28-04-2016, 08:04 PM
  Control Unit Not Working mtuk100 0 41,821 10-10-2019, 03:14 PM
Last Post: mtuk100
  Which original remote control is suitable for board CB124 Evan 3 14,167 20-06-2019, 04:26 PM
Last Post: Devs
  Remote problem Nickhh 1 12,241 30-09-2014, 04:48 PM
  lyn300 control panel andy15 1 14,807 13-12-2011, 09:59 AM
  Liftmaster 800 Remote KevinR 1 17,454 07-10-2011, 10:27 AM
  CB11 control box Intercom release button not working Moreteyne 0 10,522 14-09-2011, 03:14 PM
Last Post: Moreteyne
  Lost garage remote controller 1 19,388 25-01-2010, 06:12 PM
  Wiring Photocells on the CB11 control board Sparky 2 25,437 28-06-2009, 10:19 PM
Last Post: Sparky
