  • 19 Vote(s) - 2.68 Average
Liftmaster CB1 gates started to open themselves
(23-12-2019, 04:16 PM)RyanB Wrote: Hello,
I hope this if of some assistance.
Thanks RyanB - Are you able to give some guidance on what terminals I need to disconnect for the keypad?
RE: Liftmaster CB1 gates started to open themselves - by telnet123 - 24-12-2019, 09:25 AM
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 942 26-11-2025, 10:52 AM
  Liftmaster MYQ Internet gateway koen_dc 4 27,503 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  My swing gates are stuck at 50% open jctrotting 1 4,346 11-04-2024, 08:11 AM
  Liftmaster LA400 Defender 6 22,794 03-08-2023, 12:26 PM
Last Post: Torantrieb
  odd liftmaster scs300-24 scopie88 3 21,825 13-04-2022, 10:20 AM
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 19,667 09-03-2021, 02:46 PM
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 23,755 22-02-2021, 08:48 PM
Last Post: russ
  Sliding gates are opening/closing like someone is going in /out. gandreja 3 14,320 14-04-2020, 01:45 PM
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 35,816 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  CB1 How to learn the gates telnet123 1 18,461 30-04-2018, 01:45 PM
Last Post: Tim
