  • 19 Vote(s) - 2.68 Average
Liftmaster CB1 gates started to open themselves
Hello,
There could be a possible cable break from the keypad to the control panel which could be shorting and causing the open signals. I would recommend disconnecting your keypad from the system and monitoring whether the random activation continues. If the random activation does continue it could be a fault on one of your remotes or the receiver unit. Re instate the keypad and remove the memory of the remotes, if this stops the random activation, reprogram the remotes one by one and monitor until you find the remote which is causing the issue.
RE: Liftmaster CB1 gates started to open themselves - by pronosoft - 01-01-2020, 09:43 AM
  LiftMaster SL400EVK & 722e Failsafe Tucks27 4 942 26-11-2025, 10:52 AM
  Liftmaster MYQ Internet gateway koen_dc 4 27,503 05-10-2024, 01:30 PM
Last Post: Arnold Pow
  My swing gates are stuck at 50% open jctrotting 1 4,347 11-04-2024, 08:11 AM
  Liftmaster LA400 Defender 6 22,794 03-08-2023, 12:26 PM
Last Post: Torantrieb
  odd liftmaster scs300-24 scopie88 3 21,825 13-04-2022, 10:20 AM
  Liftmaster MYQ Internet Gateway Registration/Connection issues! Carmody 0 19,667 09-03-2021, 02:46 PM
Last Post: Carmody
  Advice on new gate install - LIFTMASTER LYN424 Leeb 1 23,755 22-02-2021, 08:48 PM
Last Post: russ
  Sliding gates are opening/closing like someone is going in /out. gandreja 3 14,320 14-04-2020, 01:45 PM
  Chamberlain Liftmaster gate problem CB1 Armstrong 2 35,816 13-06-2019, 11:46 AM
Last Post: Pop Alexandra
  CB1 How to learn the gates telnet123 1 18,461 30-04-2018, 01:45 PM
Last Post: Tim
