  • 25 Vote(s) - 2.8 Average
NIce Aria 400 unable to program gate open/close
(12-01-2020, 01:06 PM)Telboy Wrote: Just trying to complete the installation of a Nice Aria 401 kit. Problem with programming the control unit to recognise/memorise the close and open positions. I start with gate in midway position per the manual then press P3 key. Flashing warning light comes on and gate moves to close position but then stops. I expected gate to close then go to open position then close again. LED's on photocells are flashing approx once per second and the same for the Bus LED. Stop LED is on. I have checked photocells and gate stops if beam is interrupted as gate closes so appears photocells are working correctly. Checked voltage across terminals connected to motor and only 9v and power goes off once gate is closed. P3 LED is flashing which presumably indicates that the process has not been completed.
RE: NIce Aria 400 unable to program gate open/close - by Telboy - 13-01-2020, 03:25 PM
  Youtube gate specialist broke my module Harvie C 2 1,164 11-11-2025, 03:23 PM
  Nice Robus closing after photo Nexur 1 7,241 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 9,573 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 7,911 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 3,595 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 4,226 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 4,357 09-05-2025, 01:07 PM
  Mag-lock not activating after close benkay 4 9,161 13-03-2025, 04:19 PM
Last Post: ldkerlukeHome
  Looking for help with oldschool NICE gate motor gatekeeper 0 4,936 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 3,093 08-02-2025, 07:22 PM
Last Post: devlinjayse
