  • 26 Vote(s) - 2.58 Average
Altair-P gates now move in opposite direction with any change to wiring
I have a pair of gates controlled by a BFT Altair-P
They have worked for years giving little trouble. The switches on the remotes sometimes "bounce" giving a start then stop, but otherwise reliable.
Today I had trouble closing the gates.
The remote control is sometime unreliable so I used the manual over ride to try to close the gates. There also may have been a weed growing in the path of the photocell causing a nusiance trigger of the stop an reverse action.
After several attempts at closing the gate I ended up with 1 gate closed and the other gate open.
I mechanically disengaged the open gate to stop any risk of them clashing.
Now using the manual control I can reliably trigger the gates to move, but each time one opens and the other closes or vice versa.
I have put a new battery in my remote and again this now reliably triggers the gates, but one opens and one closes.
I have tried switching the power off and on.
I have tried putting into single gate mode, moving one gate so they are in step and then re-enabling normal (2 gate) mode.
I reloaded the default parameters.
I don't know of any other kind of reset to try. Suggestions?
It would appear I could make this work by swapping one of the motor's wiring,  but how can this become necessary?
Any ideas what has happened and how to fix?
Thank you
William.
Altair-P gates now move in opposite direction with any change to wiring - by william.helsby - 14-05-2020, 11:57 PM
  BFT Altair-P "Phot" message. How to bypass/Test? AdamC 0 1,457 16-07-2025, 06:36 PM
Last Post: AdamC
  BFT Rigel 5 Gates won't stay open on second press pacmanssj 1 3,356 03-02-2025, 11:29 AM
  Keypad only opens after change koruki 1 3,163 20-08-2024, 11:25 AM
  Two BFT pairs of electric gates (one remote) Harry44 1 4,258 04-06-2024, 01:30 PM
  smart relay BFT ALTAIR halt23 1 3,521 13-11-2023, 11:45 AM
  smart relay BFT ALTAIR halt23 1 3,381 13-11-2023, 11:45 AM
  Gates not fully closing stefen1978@hotmail.co.uk 2 7,383 10-10-2022, 10:07 AM
  Best BFT for closed aluminium gates rafp 1 5,628 13-04-2022, 11:38 AM
  BFT controlled gates open but don't close MikeJep 5 27,884 04-01-2022, 09:58 AM
  Sub BT oil change wbryce 4 14,900 28-01-2021, 12:54 PM
Last Post: wbryce
