  • 25 Vote(s) - 3.08 Average
spurious safety trips
I have a pair of Ditec swing gates and recently they have developed a problem.
Sometimes when the command to close is given the gates start closing then open before reaching their closed position.
Watching the control panel there is a "safety contact" light flashes on then off causing above.
The only safety feature in the system that I am aware of is the sensors on both brick piers protecting pedestrians / cars when the gates are closing.
The sensor faces are clean and as far as I can determine the cable in good.
Can I remove the sensor cable from the circuit to prove this or do I need to fit a "jumper" in the terminal block to get the gates to work without the sensors in circuit.
spurious safety trips - by cully - 28-10-2020, 06:59 PM
RE: spurious safety trips - by RyanB - 30-10-2020, 09:53 AM
RE: spurious safety trips - by cully - 30-10-2020, 08:40 PM
RE: spurious safety trips - by cully - 30-10-2020, 08:53 PM
