  • 20 Vote(s) - 2.85 Average
Mhouse left gate not closing properly
Usually this is related to the motor drawing too much current causing the control panel to trigger a safety function as it thinks there is too much friction and relates this too an obstacle being present. I would first check if the ram requires greasing to alleviate as much friction as possible on the arm mechanics. I would also check the if you are able to open and close the gate freely with the arm manually released, I would advise moving it by holding onto the motor bracket, moving the gate at the end of the leaf will not give an accurate feel as this is not where the motor pulls and pushes on the gate. It would also be advised to check the mounting A and B measurements as if they are slightly out of the manufacturers guidelines it can put strain on the motor over time and cause faults like this to occur
To check whether the motor is causing the gate to reverse or the panel I would advise to swap the motor terminals over, if the issue persists on the same motor it will be relating to that motor directly. If the swaps to the other motor it could be relating to a potential control board issue.
How long has the system been installed?
RE: Mhouse left gate not closing properly - by RyanB - 05-02-2021, 10:48 AM
  Mhouse sl10 not closing Mark Reader 1 5,750 13-03-2025, 09:56 AM
  MHouse Sl1 does not open v.ptohides 1 5,643 03-02-2025, 09:56 AM
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 7,552 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 9,704 30-01-2024, 10:35 AM
  Where can I find Electric sliding gate opener NICE ROBUS Spare Parts Mogahid Abbas 1 4,491 29-08-2023, 08:40 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 8,086 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 30,316 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 13,473 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 8,134 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 16,321 30-05-2022, 09:15 AM
