  • 29 Vote(s) - 3.07 Average
MHouse WS2S
(29-03-2021, 01:11 PM)SamA Wrote: Hi,
Please try factory resetting the control board, but pressing and holding P2 and P3 for around 10 seconds.
Once this is done, disconnect all accessories until it is just the motors wired in.
Then relearn the ECSBUS, press and hold P2 for 2-3 seconds.
Once that is done, manually release the gates into the halfway position and relearn the limits. (press and hold p3 until the gates being to move)
Hope this helps.
Hi SamA,
Thanks for all the info, I had the CL2SK tested and the main microprocessor was damaged, unfortunately not repairable as the microprocessor is coded to the board.
So a new circuit board is on its way.
A further question ------------
Is it just a transformer in the base of the unit to feed the electronics etc. or it it a power supply, i.e. with rectifiers/ capacitors etc. is there a chance that any of this or indeed the motors could also have been damaged by the surge (note neither of the fuses blew), I would not want to install the new card and for that to get damaged.
Cheers
MHouse WS2S - by Bricodust - 24-03-2021, 09:25 PM
RE: MHouse WS2S - by SamA - 29-03-2021, 01:11 PM
RE: MHouse WS2S - by Bricodust - 30-03-2021, 01:26 PM
  Mhouse sl10 not closing Mark Reader 1 5,747 13-03-2025, 09:56 AM
  MHouse Sl1 does not open v.ptohides 1 5,635 03-02-2025, 09:56 AM
  Mhouse cl2 error p2 and p3 flashes Ragnarevartov 1 7,546 20-03-2024, 11:19 AM
  Mhouse cl2 ESBus error - gate not operating yeatsie 1 9,697 30-01-2024, 10:35 AM
  Mhouse left gate blocking full open when initialising gates neil.conner 1 8,082 24-08-2023, 01:51 PM
  Mhouse SL1 won't close correctly Dartman 5 30,307 03-02-2023, 12:04 PM
  Mhouse WH2S not opening SamGate 4 13,467 10-10-2022, 09:46 AM
  MHouse SL10 closes, but doesn't open cambo 1 8,130 19-08-2022, 09:29 AM
  MHouse SL1-10 partial close NAT 5 16,312 30-05-2022, 09:15 AM
  Mhouse WS2 Gates not closing together pauln0301 1 8,361 13-04-2022, 11:18 AM
