  • 31 Vote(s) - 2.9 Average
Proteco Aster 3 ram fault
No replies! Before ordering a new ram I decided to get stuck in and find out why one motor winding was open circuit. I used an angle grinder to make two openings in the bottom end of the motor housing, then drove out the stator assembly by alternate whacks with a hammer and nail punch.  Once apart, a burn spot was visible on the bottom end where the winding had burnt out. After some dissection, I could see that the arc had vaporised wires leaving 6 loose ends, so it was not surprising that the winding was reading as not connected. After some precision soldering under magnification and trying different permutations of the 6 to give equal resistance (about 75 ohms) for each winding, it is now re-connected, the motor is reassembled, and the ram is working properly and back on the gates.
I took the attached photos of some steps of the process.
Proteco Aster 3 ram fault - by soother - 19-04-2021, 10:30 PM
RE: Proteco Aster 3 ram fault - by soother - 23-04-2021, 09:09 PM
RE: Proteco Aster 3 ram fault - by soother - 14-07-2021, 11:58 PM
  TC fault code on Q60ar control board Skydive1710 3 9,760 20-11-2023, 03:12 PM
Last Post: NormanY
  FAAC E124 fault 05 allan@amtas.com.au 0 3,464 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 23,413 26-09-2023, 05:32 AM
Last Post: max666
Exclamation Proteco Q60A stopped working xCO 0 3,361 19-06-2023, 01:03 PM
Last Post: xCO
  Q80A Fault Code kevcl15@yahoo.co.uk 1 5,583 03-02-2023, 12:00 PM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 10,154 26-08-2022, 03:42 PM
  Hello - Another Proteco Q60A/R Question! SawboMan 2 7,463 12-07-2022, 11:48 AM
  Q80A Strange fault. Cannot work it out, if setting or fault? gray 0 3,387 25-06-2022, 08:14 AM
Last Post: gray
  Proteco Q60 - FH error then close after opening Needlerp 1 5,877 24-06-2022, 09:54 AM
  proteco q60a microcontroller program arashkhan 1 5,584 17-06-2022, 01:29 PM
