  • 25 Vote(s) - 2.68 Average
Nice gate stuck on open
I hope you are well. May i ask, what have you got wired into your OPEN terminal on the PCB? As an open command can typically only be triggered by either the OPEN terminal, or the SBS terminal (open, stop, close). You should find if you wire a push button into SBS for example, this will open stop and close the gate. If you are using an aftermarket receiver which is only wired into the OPEN terminal, this could be your issue.
You may have also set the keyfob to open only, you could always do a reset of your receiver and then re learn the keyfobs in to see if this fixes the problem - as it may be a temporary glitch.
Finally, does your BUS have any flashing lights on it? If so, what is the sequence?
If you could also let me know the model of your Nice panel, i may be able to assist further.
Kind regards
- Jamie
Nice gate stuck on open - by akkers - 15-06-2021, 10:28 AM
RE: Nice gate stuck on open - by JamieF - 18-06-2021, 11:13 AM
RE: Nice gate stuck on open - by akkers - 18-06-2021, 11:49 AM
RE: Nice gate stuck on open - by JamieF - 22-06-2021, 12:42 PM
RE: Nice gate stuck on open - by akkers - 25-06-2021, 12:11 PM
RE: Nice gate stuck on open - by Michael - 28-06-2021, 09:43 AM
  SEAV LRX-2186: gate opens a bit then stops mehsom 0 118 10-12-2025, 09:42 AM
Last Post: mehsom
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 30 59,055 03-12-2025, 04:18 PM
Last Post: StefanP
  Help me identify this mystery gate opener alpha 5 5,096 23-11-2025, 02:35 AM
Last Post: alpha2
  Gates not staying open JimM169 1 2,605 21-05-2025, 02:55 PM
  Peculiar automatic gate behavior Gatefreak 1 5,014 09-05-2025, 12:36 PM
  I want to know Best Gate Lock for Security? mitasali 0 4,638 28-03-2025, 03:15 PM
  Nice Swing Gate Opener nicenotnice 0 4,504 18-03-2025, 06:40 AM
  Nice wingo 5400 and MC800 engrbhadz 0 2,185 18-03-2025, 05:53 AM
Last Post: engrbhadz
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 1 13,190 02-12-2024, 10:40 AM
