  • 18 Vote(s) - 2.78 Average
FAAC NOT AUTO CLOSING. BROKEN WIRE
Hi.
I have a set of FAAC gates. They work on a master switch a sim card opening system where my phone opens the gates.
Everything was working perfectly until last week when the gates opened and closed ok but when the photocell was tripped the gates wont close unless you dial the number or flick the master switch.
I found the little white wire had broken off but cannot find the correct terminal to connect it back to.
Even with the wire not connected the gates open and close as they should. They only stop when the photocell is tripped.
Tearing my hair out in 30 degree heat.
Any help greatly appreciated.
I've images of the board and relay that triggers the sim card. Broken wire circled in red.
FAAC NOT AUTO CLOSING. BROKEN WIRE - by Slick19000 - 21-07-2021, 03:00 PM
RE: FAAC NOT AUTO CLOSING. BROKEN WIRE - by JoeF - 09-08-2021, 09:04 AM
  FAAC Configure 443Hz remote to open partially, pause and close Ezylryb 3 5,664 11-11-2025, 03:33 PM
  Faac 740D, Open further then limit, not closing emiel 1 6,326 26-08-2025, 02:23 PM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 4,057 13-03-2025, 10:06 AM
  FAAC Eq45s , only Leaf A closing with remote Cummil2 1 3,994 13-03-2025, 10:05 AM
  FAAC S800 Single swing Gate not responding robhight 0 3,768 18-11-2024, 11:48 AM
Last Post: robhight
  FAAC problem dennisoates 0 3,392 30-06-2024, 04:40 PM
Last Post: dennisoates
  Intermittent ‘Stop’ command - FAAC 741 Sliding Gate bwel 3 9,383 22-04-2024, 03:21 PM
  Faac 415 can't reset from manual to operate mode Stephen Q 1 7,122 18-03-2024, 01:20 PM
Last Post: RXH
  Faac 455d Grantplant 1 7,773 13-11-2023, 11:58 AM
  FAAC 740 limited travel LoneStarCycler 0 6,529 24-06-2023, 01:06 AM
Last Post: LoneStarCycler
